If you are not having symptoms of a bad clutch, I say don't take it apart until you are fixing tranny, which should be soon, imo. I think if the disc is worn enough to replace it, then a full clutch job should be done. If the disc is okay, then I think just removing the glazing would be okay. ... PS: if you erase the header line before responding, we don't have to read the same line twice.
